I found this on amazon it is almost as small as the Sino KA-200 series and a lot cheaper, i ordered one to test out.
This is the unit I have on my mill and I have the 2 axis version on my lather, I very much like these but as you can see they are not cheep.I found this on amazon it is almost as small as the Sino KA-200 series and a lot cheaper, i ordered one to test out.
$54 for a slim glass scale they are $140 from anyplace else, i think i'm not understanding youThis is the unit I have on my mill and I have the 2 axis version on my lather, I very much like these but as you can see they are not cheep.
Nope, I think you understood me, sometimes I do not communicate well. I like what you found and if you want to install yourself with a touch DRO I see that as a very appealing option. I wanted to get equipment I could work with a quickly as possible so when I ordered my equipment I optioned out. The DRO's I have are very satisfying to use and I like the displays; however, what you are looking at appear to me to be just as good.$54 for a slim glass scale they are $140 from anyplace else, i think i'm not understanding you
PM makes good stuff but cheap it is not.
I have those scales (from the same Amazon seller) on my mini-mill and they've been working fine for the past year or so with the TouchDRO adapter. The PCB iside the scale read head is encased in epoxy, so figuring out the pinout was a bit tricky, but it all worked out OK without problems.I found this on amazon it is almost as small as the Sino KA-200 series and a lot cheaper, i ordered one to test out.
right now i'm more into working on my tools but i know what you are sayingNope, I think you understood me, sometimes I do not communicate well. I like what you found and if you want to install yourself with a touch DRO I see that as a very appealing option. I wanted to get equipment I could work with a quickly as possible so when I ordered my equipment I optioned out. The DRO's I have are very satisfying to use and I like the displays; however, what you are looking at appear to me to be just as good.
I had a close friend once who bought a used sail boat and I looked at it and started identifying improvements which could be made. I have carried the memory of his reply with me ever since, he said, "My hobby is sailing, not working on a sail boat".
I have built machines in the past, I have repaired and restored old machines, welders, tools, etc.... I'd rather use my tools to do something than to work on my tools....
could you share the pin out, the scale just came in and no pinout included but they look nice and small.I have those scales (from the same Amazon seller) on my mini-mill and they've been working fine for the past year or so with the TouchDRO adapter. The PCB iside the scale read head is encased in epoxy, so figuring out the pinout was a bit tricky, but it all worked out OK without problems.
Chances are it uses standard Ditron/Sino pinout (shown at the bottom of this page: Supported Optical and Magnetic DRO Scales), or the "other" Chinese pinout that some weird brands use. If you take apart the D-Sub connector, it will be pretty obvious which one it is.could you share the pin out, the scale just came in and no pinout included but they look nice and small.
ycroosh you are the best, even if you don't let us hy-jack your threads lolChances are it uses standard Ditron/Sino pinout (shown at the bottom of this page: Supported Optical and Magnetic DRO Scales), or the "other" Chinese pinout that some weird brands use. If you take apart the D-Sub connector, it will be pretty obvious which one it is.
I ordered one of these to see what they are, and can check once it's here (should be later today or tomorrow).
