I milled a face on a 2.5"x3.5"x1.5" block of 1018 steel and a 3/16"x3.5"x1.5" 1018 steel plate. The two milled faces will be fastened together. I used a 5/16" HSS end mill at 1,100 RPM, 7"/min feed, lubricated with Boelube paste.
When I checked fitment of the plate to the block I noticed a slight gap at one corner (~0.002"). Regardless of how I turned the plate the gap remained in the same place, so it appears the block has a slight low point at that corner. The affected area is approximately 1/8" deep by 1/4" long.
I plan to re-mill the surface of the block tonight, but I'd like to get some idea of what caused that low point so the same thing doesn't happen again. Any ideas?
