- Jul 26, 2011
- 4,142
View attachment 96540 View attachment 96540 View attachment 96540 Making a small hammer head.
This is a test on uploading pictures with the new format.
The hammer head is first contoured out on a lathe. You can use freehand HSS wood lathe cutting chisels,to smooth out the contours, after you rough out the shape with normal metal lathe tools. Then the hole is milled for the eye,and the cheeks are milled flat on each side. I prefer to accurately smooth out the contours before milling the flats. This helps keep the edges of the flats nice and sharp.
The eye is stuffed very tightly with fine steel wool with a hammer and a flat nosed punch. This keeps the head from cracking through the eye when quenching. These hammers were made from 1" 01 drill rod. Hardened,quenched in a gallon can of vegetable oil,and drawn to a spring blue color to be about 52 RC.
