- Apr 28, 2014
- 3,590
If we did up a poll, I would bet noone would be able to check the box that said "Never Happened to Me" - just sayin' ![Biggrin :grin: :grin:](/styles/default/xenforo/smilies/biggrin.gif)
Another option would be to take an angle grinder and cut the apex of the V of the bottom four legs. You would then the have two tabs on the bottom of each leg. Bend the two tabs inward and then weld. I had a problem like yours and it was a bandsaw. I cut an inch off except this was tubing like I stated earlier.
The saw weighs about 220lbs, so it is heavy enough to make it a pain to test fit (a big part of why I'm in this situation), but not too bad to move it around with some help.
That's pretty heavy. What kind of saw is it?The saw weighs about 220lbs
