- Mar 21, 2013
- 4,115
Re: Members' Tooling "Wish Lists"
When I started putting my little shop together last spring I was basically starting from scratch again, as my last set of little machines was over a decade ago and I lost everything. But, I'm slowly putting together what I need/want. Things I still want/need:
4x6 horiz/vert band saw (high priority, as I'm getting tired of using a hand saw...)
small bench top blast cabinet (more of a want than need as I'm not sure where I'd put it)
6" rotary table (on plan to purchase next week)
Indexer or indexing plates for my rotary table
steady rest
5" four-jaw
5" collet chuck and collets
radius turning setup for lathe (probably will have to make this)
2 or 3" boring head R8
a 3/8" and 1/2" indexable boring bar for the lathe
Co-Ax indicator
decent inspection table, 12x12 or 12x18, probably pink as it will last longer than a black one
height guage
0-3" micrometer set
gauge sets (block, pin, radius)
a couple of machinist's squares, 4 and 6"
a 4 or 6" right angle plate or whatever you call it for the mill
broaching set to 1" or so
one ton arbor press
small belt sander, or attachment for my 6" grinder.
and so on...
It's a work in progress, but I'll get it done.
Bill
steady rest
5" four-jaw
Co-Ax indicator
height guage
0-3" micrometer set
one ton arbor press
and so on...
Bill
