Mill power feed and DRO
jwmay
Dec 3, 2017
1,917
Do you have both power feed and digital read outs on your Rockwell vertical mill? How did you fit it all on there?
Burtons attic didn't display his limit switches or a DRO. But he almost included every measurement i need for adapting an X power feed to my machine. I'll look at yours again 38 super. Thanks
Reuse the bridgeport adapter, cut off the ears and blend. You'll need to fab shaft adapters/extension and a means to machine keyway slots. I did not incorporate limit stops. Had thought of using the DRO scale mount but ran into clearance/attachment issues, brain hurt so I quit.
I used 1x1 aluminum angle to mount the DRO scales. 1x1.5 or 1x2 might give you the room to add limit switch. Make a clamp-on limit stop, saves machining. If I find a rem, will do the same on mine.
