- Apr 9, 2023
- 225
I did some more searching and couldn’t find anyone that sells a 12dp 2:1 in a 32/16, but looking at the Boston Gear catalog again, the 12dp 36/18 might fit. Before you put everything together, can you check and see if you can fit a gear with an OD of 3.1”?
I'm pretty sure that I can; the stock gear is 2.75-ish and there's room to adjust things.
I eliminated those the first time thinking they were too big, but if the gear will fit, it might be a solution. The pinion would need to be further back and instead of adding a spacer, might need to turn the hub shorter. Same with the gear. The part numbers are L152BY-G and -P.
I think that's what would be required. I'll look the dimensions up and see if it's easier than the ones I already have. Thank you!!
