I have a grizzly 0755 with a 5" vice and took the swivel base off and had to mount the vice inbetween the front two table slots, using some hold downsI just installed a Shar's 5" 550V vise on my G0755. I used the middle slot in the table and could not get to the back side of the vise keys I was step cutting down to 1/2" (actually .544") from 5/8". I may have to switch from the middle to the outside table slot for some work. I like the 5" and would not want a 6" vise hanging off the front of the table. By the way the keys on the bottom of that vise were so hard it just destroyed my new HSS end mill, I used a 1/4" shank carbide bur and that cut away at the key, after I tried to file the sharp edges and all the file would do is slide across the key, man they are hard.
My grizzly 5 inch vice with swivel base was 167.95 from grizzly. i threw out the little blocks because they were a joke. took off the swivel, and mounted the vice be careful not to cut yourself on the razor sharp edges of the jaws. used a stone to cut down the edges so no one will get cut again. I guess you get what you pay for.
I am saving u
