- Feb 8, 2014
- 11,145
I fired up our new (to us) press brake and the motor overload tripped out after a time. OK, grab the amprobe and check the current draw on the legs: 10, 10, 5. Well that's not good. FLA motor current is about 16 Amps so 10 is about right for idle current. But the low leg is very weird.
4KW (5.5HP), 9 lead, Y connected (confirmed), 220/440 volt. Metric frame, made in France. Circa 1976
The motor lead numbering is not original, have been re-tagged. There is no wiring diagram on the motor or in the electrical documentation for the machine.
Here are the current connections in the motor box. Keep in mind this is a 9 lead motor, leads 1, 5, and 9 do not exist
It should look like this
I suspect one of the pairs have the polarity reversed. I need to go through the excersize of re-mapping the windings.
Stay tuned.......,.
Stay tuned.......,.
