Motorcycle top triple clamp machining help in CT, 06468
DaveBarbier
Feb 14, 2016
121
Hi everyone, I need some help finding a place in southern-ish CT (Bridgeport, Stratford, Oxford, Danbury, Fairfield, etc. The shop I normally use (Garrick Machine Co) google says they’re permanently closed.
Small job, just enlarging the hole in the aluminum tripe clamp to 1.913” to a depth of .500” then the remainder of the hole enlarged to 1.177”.
Thanks!
And yes, I’m right near Bridgeport, CT...home of the milling machine...and I can’t find a machine shop.
Sorry I never replied to this. Thought I did. I found a local place and they did a perfect job. I remembered on one of my motorcycle routes that I saw a mailbox that has a micrometer made of wood on top of it as a decoration. Turns out it’s a small machine shop.
If you want to take a vacation in Montana, I'll do it for you.
If I ever make my way out there and I’m in need of any machine work I’ll let you know, haha. From what I’ve seen in pictures it’s a beautiful state.
