My Clausing 5913
jwmelvin
H-M Supporter - Gold Member
Jan 11, 2018
1,530
Back in March of this year, I bought a number of tools from a local estate. One of my favorites is the Clausing 5913, 12x36 lathe, which came with a full compliment of chucks and collets, taper attachment, steady and follow rest, etc. Unfortunately, no metric threading setup (which requires a new quadrant and some gears, and is impossible to find). Here's how it sat when I bought it, and me getting it into my garage workshop:
It seemed to be in pretty great shape, so I mostly just changed the headstock and apron oils, wiped it down a bit, and lubed it. The variable-speed drive, which can be an issue on these, appears to be in fine shape:
I made a spanner to turn the chuck retention collar:
I modified some shelving from the prior owner to make a storage cart:
I modified a shelving unit to hold tools:
The lathe has been great and I really like it. The taper attachment is a little crusty and there's sometimes a bit of smoothness lacking from the cross-slide screw, so I decided to disassemble from the carriage up and make sure everything is clean and as well cared for as possible. That was last night, and it seems pretty good to me. I'll be cleaning up some parts as I reassemble them, and replacing the felt wipers.
The parts:
Up close on the cross slide and its gib:
Up close on the carriage ways:
So there's a bit of scoring on the ways, but nothing major, and it doesn't seem all that worn. I have not measured anything on the lathe since leveling the bed to remove twist.
Here's the apron gearbox, which looks perfect to me and I won't be taking it apart further:
I just thought some of you may enjoy seeing the pictures. I welcome any advice while I have it apart. There don't seem to be many things I should do besides clean and reassemble with the new way wipers. I have a new seal for where the cross-feed screw goes through the carriage, though I've not seen any leaks.
-jason
I tried to take a pic of mine this morning Jason but it got lost in the garage . Maybe Sunday you can help me find it ! :big grin:
It's right over there Dave, under those other 30,000 tools.
Hey ! You were right . :grin: Mine came with the optional beam clamp accessory package , along with a bunch of other crap . :laughing:
That's what a good used lathe should look like, where you don't have to do a lot to it, just start using it
Good find! I like the collet rack too
-M
You lathe looks like it had a very pampered life ! Enjoy using it .
I got everything cleaned up with my taper attachment, cross slide, and compound. Then centered the tailstock, which shows no droop or lateral misalignment.
Today I made a tool-height gauge. Just a fixed piece that I somehow, miraculously cut to length within half a thousandth of my target. It’s a piece of hydraulic shafting (hardened chromed exterior) with an aluminum base section.
Beautiful! You may have done better on you height gauge than you realize! Joe Pie has a good video on making the same style for anyone who might be interested!
Thank you. I do remember that video and used a similar technique because of it. First I was stacking gauge blocks to use a DTI like Joe and then I remembered the fancy dial indicator I hadn’t yet used, so used that to compare my height gauge to a turned section of stock:
That let me figure out how much to cut off and also check it when finished.
“ I remembered the fancy dial indicator“
That sounds too familiar!!! Lol those type of height gauges have to be the best out of any of them. I would encourage everyone to make this style.
