- Jun 24, 2015
- 44
About a week ago I was finally able to bring home my 932 and get it set up. So far I have cleaned it up most of the shipping grease and grime. I ran it through all the gears in forward and reverse to break it in. Only issue I had in getting it going was trying to figure out the color code for the power wire, also the bolt provided for the DRO arm was too short. No biggie.
After the break in I spot faced the area of the vice base where the T nut bolts hold the swivel base to the mill. I only took about .015" off. Just enough to provide a nice flat even surface for the nut. I'll need to do some more cleaning on the T nut slots as the 9/16 T nuts are really tight in some spots. I've also done a little machining on an AR lower. Trying to salvage the mess that I made with the drill press and cheap cross slide vice.
It has become pretty clear in working on this thing that it is too low. I need to build a stand to go under the base. I was thinking about raising it about 6 or 7 inches total. For those of you that have 932's and have made stands, how tall did you make yours?
I have noticed a few quirks about the mill. The quill DRO is a little sticky and jumps around a little. If I can't get to start working better I might replace it with a Mitutoyo unit. Also the travel stops for the X axis power feed seem like they are in too far. I haven't really taken a look to see if there is a reason for this. Can I just move them out a little? The travel stop switch hits the back of the Y axis hand wheel. I think this is a known issue. I looks like the block the switch is mounted to could be a little thinner. But I'll probably make a spacer for the hand wheel like Ray Caniglia on YouTube did.
