- Dec 20, 2012
- 9,422
If the conversion is a common one then the bearings will be known and you may be able to get them locally. Perhaps one of the guys who has done this can give you the numbers on the bearings he put in? If they were not tapered roller bearings then you can have a bearing supply house convert the ball to tapered bearings and you'll be good to go.
If you must turn it, a 4mm overall reduction in diameter won't affect strength much I should think so its doable.
If I was to do this job I would chuck it somewhere in the middle to limit overhang and NOT use a live center. I would use a 4-jaw chuck and dial the part in before cutting it. I would make left hand cuts, feeding toward the tailstock. The reason for all this is to avoid cutting a taper in an area that must support a bearing with tenths tolerances.
With regard to the inserts, I suggest using a small nose radius. You are going to be taking very small finish cuts and the smaller nose radius will allow you to bury more of the nose in the cut to reduce the tangential forces you will encounter. HSS is better in this regard but if you have a insert with a nose radius of 0.007" or less then you'll probably be just fine. I further suggest you max the speed on the lathe and feed manually using lots of coolant to reduce the chance of a built up edge and to enhance the finish.
None of this is difficult to do. I could probably have done the turning job in the time it took me to write my first response. If you can turn steel with precision then this will be a simple job for you. BUT practice first!
