Need gears modified for. Logan 820 Lathe
vincent52100
Mar 26, 2014
211
Good morning. I have a Logan 820 Lathe that has some bad gears in the quick change gear box. The replacement gears from Logan are way beyond my budget. I have found gears that will work but need some modifications. The thickness needs to be reduced and the bore enlarged for the bushings. There are two 16/32tooth gears and a 40 tooth gear. Haven’t received the 40t yet. I’m near Asheville NC.
Any help or advice would really be appreciated.
Thanks!
You should be able to use your lathe to bore and face the gears. The hand cranks should still work.
If not, I'm sure someone local can help out.
I was tempted to try it myself but am not sure I have the skill. Also I only have a 3 jaw chuck and am concerned about accuracy of it for boring.
Thanks
That would be great! Should I PM you for info!
Thanks
You need to NCJeeper is a great guy and will do you right. I was going to offer but he beat me to the punch, besides I’m on vacation at OKI so it be next week for me.
Good evening. Thought I replied earlier but it looks like it didn’t go through. I would really appreciate your help. Should I try to pm you?
Thanks very much!
All taken care of. Gears modified and shipped back. :)
