- Dec 3, 2013
- 1,845
I don't think you would be disappointed with either one.
I went with the PM-1440GT because I wanted the larger spindle bore, larger swing, D1-5 spindle nose, enclosed gearbox, foot brake, pull out chip pan and coolant system. Mine is one of the first made and at that time it was priced $1,000 less than it is now so it was a little easier to justify the cost difference.
Don't be put off by the D1-5 spindle. There are plenty of chucks to choose from that can be had with that configuration. It is a significant step up from the D1-4 which I had on my previous lathe.
Now having used a lathe with a 2" spindle bore I would not want to go without.
The only quirk to the PM-1440GT is the spindle taper is not a standard taper. PM calls is a MT5-1/2 which isn't standard. They do provide an adapter to use a center. The only thing it really affects is if you want to get a collet closer. I believe PM has them or you can have one made to order from JFK Precision.
