Can you give me an example on how to use it?
Guys,
I'm reviving this thread because I need some clarification. My backplate with a spider is used instead of a lathe dog when turning between centers? I was told this by a guy at work and not sure if this is correct.
But not with abrasives!Clean the surface up on it as well as the taper in the spindle
With a lathe dog, correct?The sleeve in picture 2 fits in the spindle taper to reduce it from MT5 to MT3. With it in place an MT3 holder or tool can be inserted in the spindle.
Okay this is what I thought but had some slipping. I'm not sure if it was the taper reducer or the center in the reducer. Is there a proper way to set the reducer and center? I lightly tapped the reducer with a dead blow I didn't do this on the center. I thought I read somewhere you should put a twist on the reducer?No, the MT3 tapered tooling would just need the adapter. The outside taper would fit the spindle taper. No lathe dog is necessary for driving.
"Billy G"
Thanks for the link.
