I have an 833TV I picked up new/second hand, and honestly I can say I am a tad disappointed in the spindle speed on this mill. I Have it converted to CNC and after getting everything all set up and making a few chips for the first time I found that the spindle gets hot after running around 2800 - 3000 RPM for about 15 minuets ... Hotter than s should IMO, hot enough that you almost cant touch the nose of the spindle. I contacted PM about it to see what the specs were for the spindle nut hoping that all I needed to do was check to ensure there was the proper mount of grease and that the spindle was not overly tight. After conversing with the PM guy Mike IIRC (90% sure it wasn't Mat) I was told that the spindle nut wasn't much more than hand tight (sorry I dont remember the actual torque spec off the top of my head) but I shouldn't have to worry about it as the machines "weren't meant to be ran at those speeds for extended periods of time"....
Why advertise a mill that as capable of a specified speed if it is not usable at that RPM. Needless to say I still plan on taking the spindle apart and will probably at the very least replace whatever china bearings are in it with some much better Timken or SKF bearings. .. Between that and the waranty issue I am a tad upset with my PM experience so far.
