- Aug 22, 2012
- 4,124
I have a major problem with one (or more) of the steel posts holding up one corner of my carport.
It meets the corner of the house eaves as well.
I found out the other day it was full of water where the drips from the gutter seep past the fixing bolts at the top.
I drilled a small hole to drain the post but that obviously only lowers the water to ground level and if the building code was followed in building this carport then there is a further 1 metre deep set in the concrete.
When the rain eventually stops I will drill a 1" hole to slip a pipe in to the bottom and pump the water out.
I will pump hot air back in to dry the inside.
Is there anything I can pour into the post to prevent further rusting inside?
Oil would be no good as it would float on top of any water that did get back inside.
