- Feb 25, 2021
- 3,166
Clough42 just released a youtube video using a Scanning electron microscope to analyze a drill bit failure. Gives some good high level summary of what is trying to be achieved here, obviously without the imaging.
Yes, and yesHi Mark
Just to catch me up here - I take it you are making up a HV supply for the PMT you recently bought?
Is it that it is a devoted "ripple remover", like a very low pass filter?
For less than ten bucks, I think you made a smart choice. One can add some electronics to dress up the output to get it regulated and clean. "Regulated" is the key word. Keeping a fluorescent backlight display lit is not like keeping a PMT gain nicely constant.Yes, and yes. I ordered a couple of these, which can output up to 900VRMS, so the peak voltage should be around 1200V (a guess, since I'm sure that the output waveform is not a sine wave).
In the actual circuit, the inverter's Vin will be driven by the buffered output of the integrator. Another option is that the inverter has a 0-5V "brightness" control, but that may just change the duty cycle of the waveform. I will need to make myself a high voltage probe so I can safely examine the waveforms on my 'scope.
The inverter frequency is between 40 and 70KHz so that will be easy to filter out. I'm using much more aggressive filtering because I want to make certain there isn't much low frequency noise present, which will modulate the gain of the PMT.
The inverter can output up to 8mA so I definitely will need to be careful when using it! The 1 meg resistor on the output is mostly there to reduce the maximum output current. And the actual supply won't have a 47nf capacitor out there, either. It can be much smaller, since the current pulses coming out of the PMT are very short.
Sorry to hear about your tooth. Dental problems can impact your entire immune system so even if temporarily painful you did the right thing.For less than ten bucks, I think you made a smart choice. One can add some electronics to dress up the output to get it regulated and clean. "Regulated" is the key word. Keeping a fluorescent backlight display lit is not like keeping a PMT gain nicely constant.
I use two approaches to aggressive filtering. Low pass filter type, with lots of energy storage as in "smoothing capacitor" works if the storage is so massive that it can supply current transients without significant ripple. Using a less storage higher impedance very filtered derived voltage can be used as a smooth regulation reference, to a fast, high bandwidth active device like regulator or integrator, able "regulate away" the ripples, and noises, just by being faster. High voltage regulation in the usual format is a bit more tricky.
My PMT tube does not have any circuit in there at all. Mine just has a socket and a bunch or wires.I have to make the HV supply, and also the set of electrode voltages.
At home, things are just getting more chaotic! Yesterday, I had (my first ever) tooth extraction. It was from upper right, and now, I am nursing the wound. It's the kind of thing that can put a damper on the whole day.![]()
Hi Mike - welcome to xrf thread.I've actually followed this complete thread and it's a fascinating read, but SO far over my head!![]()
