- May 27, 2016
- 3,479
Regarding trying to restore a scintillator, there is, unfortunately, no easy way to remove the water. Usually, it is possible to reverse a physical process, but here, it may involve some chemistry happening. I suppose there is nothing much to lose by putting a very cheap (failed by water) Na(Tl) scintillator into an upturned jar on a metal plate with a outlet to suck a vacuum. Then, add to that, some arrangement of suitable heater wires arranged around it, and include a thermocouple.
I think, get a vacuum, and then heat, not too fierce at first. If there is actual free water in it, it may turn to vapor and crack the crystal. Maybe for a while a bit below 100C. Then, go slightly above 100C. I all is still well, then cook more, looking for transparency, but stay below 924K, or about 650C (or 1204°F), when it melts. If it was a good crystal before, it may remain so, without defects, is all that has happened is molecule hydration.
So - we try the AI engine, and this is what we find ..
The main posting reads..
Repairing or reworking water damaged NaI(Tl) Crystals
Post by SM Packard » Tue Mar 14, 2017 5:22 pm
I have acquired a number of high quality NaI(Tl) crystals for use in scintillation detectors. These crystals were made to very high standards of quality, but they are old, 50+ years.
The crystals are no longer clear. They have yellowed as a result of absorbing water, as the material tends to do. This obviously decreases the sensitivity and accuracy of the crystals.
Several years ago, there was a gentleman who said he could "rework" these crystals and restore them to their original state. I sent him a crystal and was very satisfied with the results. It went from looking like sweet cream butter to being as clear as glass.
Unfortunately he has since passed away, and I have no idea what method he used to draw the moisture out of the crystal.
I have hypothesized that it may have involved using a vacuum chamber or heating (or both, heating the crystal in a vacuum chamber) It may have also involved exposing the crystals to some kind of hygroscopic material, such as silica gel for some period of time with or without heat or a vacuum.
Whatever the method he used was, it seems to have worked very well and he seems to have taken it to his grave. This is deeply unfortunate, as high quality scintillation crystals are not easy to find, and these vintage crystals are excellent, but need to be dried.
For all I know, maybe he just put a hair dryer to them.
Does anyone have any ideas as to how I may be able to dehydrate these crystals so they can be used more effectively?
So maybe we don't have to cook it to near red heat
I don't have a temperature controlled (anything) yet, but I am tempted. Any photodiode that can see the one wavelength visible blue light can do the rest, even if it needs a low noise amplifier to help it.
That is encouraging! There is more - it seems it has been done -> HEREAnswer
To repair water-damaged NaI(Tl) crystals, one method involves baking the crystal at a high temperature to remove the absorbed moisture. This process can be done by heating the crystal in an oven at around 100-150°C for several hours. Another approach is to encapsulate the crystal in a hermetically sealed housing to prevent further exposure to moisture, ensuring its protection from water damage.
https://fusor.net/board/viewtopic.php?t=11360
