- Apr 12, 2013
- 32
Hi everyone.
I received a new g4003g just a little over a week ago.
Thought I would post some pictures of the machine and I also have some questions.
The machine came with 2 wrenches for the 3 and 4 jaw chucks. It also came with a square female wrench. What is this wrench for?
I read through the manual about threading and have successfully cut a 20tpi thread. Since the lead screw is cut with inch threads you can use the thread dial for all tpi threads. The manual said do not use the thread dial for metric threads. How do you stay with the thread for each pass if you can't use the thread dial. Or can you just engage the half-nut at any point?
I a sure I will have some more questions but no one is going to want to read all my rambling at once. So here are some of the pictures.
I was not very happy with the paint job on the machine. Here is the worst area. Grizzly is sending me 2 cans of paint.
One of the tool posts is not tapped very strait. They are sending me another. Don't see why it still could not be used but it does look stupid.
I ran the break in period with the side cover off. noticed that the key was coming out of the key way when i shut down the machine to change speeds. I lightly hammered the key back in and noticed the set screw was loose (thought it was strange the set screw was 180 degrees from the key way) so i tightened it up and ran the machine some more. About 20 min later I heard what sounded like a pellet from a pellet gun hitting a bucket on the other end of the garage. Shut down the machine and saw that the key was gone. I tapped a 10-24 thread in the pulley on top of the key way and installed a set screw. I have never seen a machine where the pulleys don't have a set screw over the key way.
Here is my added set screw.
more to follow.
more to follow.
