I have an Emco Compact 8 lathe which is belt driven and therefore supposed to be quiet but in reality it is far from being true. At 500 RPM, the noise level is acceptable but the noise will increase very substantially to it's peak at 850 RPM and then subsides a bit at 1700 RPM. When the noise is at it’s peak, I can see the spring for maintaining tension in the belt vibrating along it’s axis. I therefore suspect that the spring is resonating when the machine is running at 850 RPM , may I know if there are anything that can be done to reduce the noise ? E.g. Can I attach some weight to the spring to change it’s resonating frequency ? may be put the spring in a tightly fit tube and coat the spring with spring tar ? Here are the videos of the driving pulley system running at different RPM :
500 RPM :
850 RPM, you can see that the spring is vibrating :
1700 RPM, the noise level is lower but my camera failed to capture the difference very well :
500 RPM :
