- Dec 18, 2019
- 6,631
So far, I've only found one place, theoringstore that carries 2.5mm(CS) x 49mm(ID) orings. They are only 20.1 cents each, but have a min order of $5 and a flat rate $10 shipping. So about $15 for 25 of them. McMaster has them $20.60 for 10 shipped. I'm trying to fix a back flow valve that is leaking. There's two o-rings, a size 123 which I have a bag of, and the 2.5x49, which I haven't sourced yet. Grainger might have them, but I need to travel a bit to get there. Do you need to be an industrial customer with Grainger? I thought that was true at one time.
Cheap o-ring kits don't go this large.
Of course I only need a couple, 10 would be a lifetime supply, I'd guess. Are there any other sources that might be less expensive? Yeah, being cheap I guess, but wondering if there might be a better source.
Searching online at hardware stores is utter futility - the websites seem to have anti-search algorithms installed. I have never seen more irrelevant results. Tell me, what does a metal number that you screw on your house have to do with a metric rubber o-ring? Struggling to see the relevance, yet that was the first result! Might call a HW store, maybe they can tell me if they carry metric o-rings and their max size they stock. Don't mind going and picking through the boxes if there's a chance of success...
