I was working on a drawbar hammer for my PM727. It came it good except one issue. I only have a Unimat for a lathe and no tool holder, so I was trying to do everything on the mill.
The issue came when I wanted to turn the brass hammer head down to match the OD of the hammer head. I proceeded to mount my shiny new import boring head, center the stock and use the machine in reverse to turn the OD of the part. Where I ran into an issue was the boring head unscrewing itself from the shank.
Seems I can't turn CW since the boring bar cutter will be on the wrong side and CCW makes the tool fall off. Is there a way to do this (maybe a backward boring bar?) or is this a bad idea in general (get a lathe)
In the end I made it work but the surface finish was horrible. If I can figure it out I have more brass to make another face with.
