Hi Folks
IU am doing some maintenance on my chinese lathe. Well in one part there is a set of bearings on the lead screw with an oil feed hole in the bearing carrier - but alas no one connected the bearing carrier to a point where it can be manually oiled. No oil gallery.
I plan to put one on but can anyone advise where to get the small (6mm) brass fittings with the centre ballbearing which are used to allow oil in and keep dirt out.
Thanks in advance.
mal
Thanks in advance.
mal
