Here is a set of Lufkin Tubular Inside Micrometers, not very unusual. However the second photo is of a Lufkin 9A Height Gage Attachment for the inside mikes. You can measure between shaft using this. It has a 3/8" collet in the top of it, and I have also used it with a dial indicator as a depth gauge. It also has a beautiful case hardening on it.
Another unusual accessory is this Brown and Sharpe height gauge attachment for a combination square.
Ames Hole Test, .625. Also, two tachometers (hand held). One Starrett (black) one B&S. Yup, that first one that Don put up is a doosey. Havin fun yet? :lmao:
A few more of my indicator collection. A couple of Gladwin test indicators, these also have a scale on both sides and no reversing lever. They require a Gladwin holder to connect with anything else.
A couple of Starrett 564's test indicators. These were discontinued not too long ago. Unique to these is the tip will rotate 360° independent of the body. They also have no reversing lever.
An Ideal Tool Co. test indicator on top, also no reverse lever. Next is a Lufkin 199A, also no reverse lever. The bottom indicator appears to be homemade, and doesn't have a return spring.
