OT, comming soon...Scag Turf Runner 48 inch 20 hp
tq60
H-M Supporter - Gold Member
Jan 11, 2014
2,226
We have an older Scag Turf Runner that we have used for our 1-acre place for many years, we bought it used in 2005, gets maybe 1 to 2 hours per summer week running time.
It is located in Central CA near Fresno.
This is a Z-Mower with the deck out front with the rear box for collecting grass clippings.
Looks and operates like a Walker.
Has a lever that switches from collect or spread for clippings.
We did rings and new valves a couple of years ago at 1100 hours and all tires are fairly new as well.
All new seals in the deck gearboxes.
Includes service manual for mower and engine.
New electric clutch last year, rewired with relays added for current switching.
The interlocks are not proper. Most not connected, except for the drive one, must be in neutral to crank.
Spare gearbox set, left, right, and center. Oil seal failed on one of the blade units, causing bearing fail and broken housing that could be repaired. These are spare parts.
We are getting a new diesel Walker this week and no longer need the old one.
It needs a belt and blades, and it is hard starting if air cleaner is on for the first start. It runs fine after that. This was a new issue a couple of weeks ago, looking into it.
Photos to come later.
Starting at $2000.00 or maybe trade for something.
TIG welder, ATMOS clocks...
Sent from my SM-G781V using Tapatalk
