- Jan 22, 2022
- 128
Sorry… bear with me! I’m still very new to this and learning.I am somewhat confused as to what you want. You mention an outboard spider that would mount on the outside end of the headstock and then show a picture of a fixture that would either replace the chuck or be held in a chuck. What type of lathe do you have?
If all you want to do is thread the end of the barrel, you can do that between centers. The threads will be concentric to the bore. No fancy fixtures or dialing in required.
My plan is for something that will replace the chuck. I’ve been under the impression that some barrel bores are not true to the outside of the barrel. My fear was if I did my work between centers the threaded end might still be off and risk a baffle strike in a suppressor. Maybe I’m completely wrong.
By using something like I pictured in my original post I figured I could adjust the barrel perfectly with indicators and a correctly sized pin gauge in the bore of the barrel.
I originally saw someone doing this on YouTube and I can’t find that video for the life of me now.
Although I do want to make something for the end of my headstock (outboard spider?) eventually, it just won’t work for shorter barrels. The bore in my headstock is quite long. I have a 13” Colchester.
![FF490217-EDD8-4E3A-B320-F71DE36BA323.jpeg FF490217-EDD8-4E3A-B320-F71DE36BA323.jpeg](https://www.hobby-machinist.com/data/attachments/370/370027-bce4aa76aa9662db61ba6df96fbaa724.jpg)
![338B5E70-93DC-4874-82B0-BFC7C5153459.jpeg 338B5E70-93DC-4874-82B0-BFC7C5153459.jpeg](https://www.hobby-machinist.com/data/attachments/370/370028-00d1d519012a9f9db52c4c4b8d01d3eb.jpg)
