- Apr 23, 2018
- 6,603
So, I've been deviating a little bit and adding PCC to my match schedule. It's stupid fast and lots of fun. One thing we all want is less bounce from the red dot. Less bounce is faster follow shots, which is lower time on the clock. There is a company that makes an AR9 buffer like this, but I figured I could do better. I got a 15-lb flat-wound spring intended for a 1911 to give me much more travel before reaching coil bind. I chose the weight because the original was a 20-lb spring. I was going 25% under because I'm increasing the travel on both sides by 1/2", or 25%. Everything fits and function checks. I decided to cut down the length by 1/2" to better resemble the standard carbine buffer after the pictures were taken. Took the weight down to 5.9 oz. Anyway, it will be nice to get this thing to the range and ring some steel.
