Picked up a Reid 618P
slodat
H-M Lifetime Diamond Member
Jan 20, 2021
296
I’ve been keeping an eye out for a nice surface grinder with auto feed for several years. This guy popped up on Craigslist:
Price was right. It was even better in person.
330 miles each way made for a loooong day. I’ll unload in the morning.
I’ve searched high and low for a manual. The auto feed has quite a bit going on. I welcome any input or advice on how it may work.
Nice score. I have an older model 2c.
My recommendation is to buy a couple different brands of grinding wheels and start grinding everything you have laying around the shop flat for practice.
It is a LOT harder than it looks to get something perfectly flat. It is easy to get it shiny and kinda flat but it takes a lot of effort to make it really flat.
Don't buy anything but 46 or maybe 60 grit wheels to start. And look for H,I or J hardness.
Joe
Joe- thank you for the advice.
I’m still scratching my head on how to unload. It wasn’t too stable on the forklift forks when we loaded at the sellers shop. I have a forklift, but the approach to my shop is a little problematic for a load that’s not stable on the forks.
I have a gantry that I can back the truck under. For the life of me I don’t see a good way to sling it from above.
You may have four tapped holes at the outer corners of the upper part of the main base casting. I see two holes on the pictures you show. One of these is adjacent to the strain with the cord leading to the limit switch on the saddle. Here is a link to a newer manual which mentions similar holes being tapped for 5/8-11 lifting bolts. Unfortunately the picture (page 16) in the manual is upside down and hard to read: http://vintagemachinery.org/pubs/3348/26236.pdf
Nice find. Is it a ball way or flat/vee way machine?
