Machine is now in the basement shop. Nicely painted thanks to my wife.
Ran the spindle for the first time today after wiring it up. I am using the original
circuits in the box. Very old school.
I noticed that the spindle gets quite warm and it leaks grease. I did replace the
lip seal on the spindle. I got the grease from Replacement parts Inc. Had a bit of trouble
getting full 1465 spindle rpm....motor would bog down. Other rpms seemed fine...any thoughts.
The feed drive mechanism works nicel as well, but I need to replace the silent chain as it is very stretched.
The trip out lever works grat in both directions. I noticed that the feed drive motor does not reverse when the
spindle rotation is reversed. Not a big deal since I can select table direction manually up front.
Like others I broke the machine down into large sub assemblies. I loaded each piece after cleaning with a wire wheel
and de-greaser and used an engine hoist to lift parts onto a refrigerator dolly and strapped down hard to it.
My crew helped me slep it down the basement . Friends from work and my sons had a hand in it. It was not too bad to get down.
After mechanical inspection, cleaning and learning, the machine was rough painted by my wife. The detail painting was just done today.
She's grey trimmed with royal blue. Shop colors here are Infantry blue but I could not find it at an affordable price.
The sight glasses had to be replaced due to them being cracked and leaking oil. I had 2 glasses water jet cut out of 1/4 " thick poly carbonate.
They are swaged in pretty tight. Slight leaks were dealt with using gas fitters pipe dope.
