It's not a stub tooth form he has or extended tooth depth. It's where they make the pinion OD oversized or undersized, depending where the pitch diameter needs to fall. The gear hobber hobs or generates the tooth form according to the P.D. needed. The depth of the tooth does not change, just the shape of the tooth. And it's this shape that cannot be cut using involute cutters to cut.
Ken
Ken, trying to get a better understanding of what is being said. Can you elaborate a bit more.
As I understand the shape of the tooth is formed based off the PD, this is the same for any type of gear cutter- shaper, hobber or involute. The reason an involute cutter has a range is due to the size/shape of tooth for the given PD, it changes slightly but that is why you have cutters ranging from 1 - 8 to cover particular sets of teeth. But, you can get an involute gear cutter with a specific tooth count (a bit costly, ~$400. I had to buy one), but very accurate and it will cut 1 - 2 more or less teeth effectively.
I ended up getting a gear shaper over a hobber as it has many more uses, but I will maintain the capability to use involute cutters as they are just as effective. If you are looking for precision, a hobber and shaper is the way to go.
For what Daryl is doing, an involute cutter is great. The things that need to be figured out is the specific tooth form, DP / PA, and if it is a stub, regular or extended depth tooth.
But, I could be missing the point and completely off target. Gears can be so simple yet so confusing.
