- Mar 21, 2013
- 4,063
Feel for a notch worn in the drive belts. If the spindle stopped and the motor was going it takes very little time for the motor drive pulley to make a divot in the sides of the belts. Might be visible but might be hard to see. Rotating till you feel the spot and then checking that spot on the drive belts (part that is then on the motor drive pulley) you might find a wear spot in the sides of the belts that makes the belt jump once per revolution when it passes the drive pulley.
Parting can be intimidating, but to slow sfpm can be a bigger problem than to fast as far as the grabbing.
Yea, I won't go into how I figured THAT out...
