Thanks guys for all the posts. As you can see in my sign. line I have been busy gathering machines and tools for my home/farm (some of my own gun work) shop since I retired. This mostly started when I had a gunsmith friend, who has a Sharp 1340VS that I love to operate, build my last 1000 yd target gun, I'm not sure weather to cuss him or thank him. As you can suppose I have spent way more, many thousands, than I thought was possible. My PM1030V was adequate for most of my needs for around a year then ballooned from there.
My real needs stop with a quality 12x36" lathe. I needed to work some 1 3/4" round stock for a friend a while back and couldn't. I decided to get a larger lathe because a 1" spindle bore won't do much in all reality.
Now we come to my wants/needs list. I want a pull out chip pan, cast iron base, gear box with the least change gears possible, two axis DRO, over 1.5" spindle bore (2" would be nice), 2HP minimum motor, highest quality (9002 factory Chinese or if possible) Taiwanese lathe. There are probably other items I am forgetting right now but you get the idea. I also want to go 3 phase if possible.
When I was looking for a mill I started thinking a PM25 but after some time and persuading I ended up with a 1984 full size Super-Max knee mill, (and boy am I glad I listened to my friend), that I love to use.
So when he said get the biggest/best lathe I can afford, I am going to listen to him this time again, here I am and the reason for the thread.
I hope that made sense. I have decided to weigh out the PM1340GT, PM1440GT and the PM1440GS (just because) and get the best I can afford.
I'm curious, a question for those of you who have a PM1440GT /w/ 3 phase. Where is the door located that holds the electrical components?
Have any of you used a Lenze brand VFD, their blue ones, they are American made, on your lathe? I have one on my mill and love it.
I changed the name of the thread to reflect where it seems to be going.
