Possible motor for mill
DavidR8
Staff member
H-M Platinum Supporter
Oct 16, 2019
6,611
This came up in my feed today.
I’m considering it for my mill. But honestly at this point my understanding of using a VFD for a 3-ph motor is that I can spell VFD. And motor.
My goal is to have to fuss less with belts on the mill as I’ve discovered that it’s a real pain.
Currently my mill has a 1hp 1-ph 1740 rpm motor. Speeds range from ~200 rpm to ~2100 rpm.
Would I be making a mistake by picking one up?
Looks like a decent motor to me. You may have to build an adapter for mill to mount it up. And perhaps something to adapt to the pulley.
I leave the belts alone most of the time, but do occasionally have to move them if I want large speed changes. Usually only for really large stuff like the spacer I recently modified.
I run from about 30hz-120hz. About 50-200% speed. I also have a back gear available that drops a lot of speed.
Thanks @ttabbal
I’ll see if the seller responds.
Any recommendations for a VFD? Did I spell that correctly? ;)
the only thing that may be a problem is the voltage.
the motor runs on 575v 3phase
What voltage should I be looking for?
Plus if they are compressor motors the rpm might be higher than 1720
i believe your low voltage should be 208, 230 or 240v- a 230v motor would suffice
575 is high voltage
Awesome! Thanks gents :)
