I got a little more work done. Trying to setup and run two machines is a little taxing, and the lathe parts run is the priority right now. The press feeder is more of a fill in at the moment..... Until it becomes a panic.
This is the slide plate that holds the pressure roller. You'll see how all of this goes together later. It was a little exciting going 3/4'' deep in steel with a 1/8'' end mill to do the finish profile to clean up the corners in the center slot. The bulk of the material was removed with a 3/8, 4 flute carbide endmill.
This is the bearing housing and adapter plate for the motor adapter.
And one side finished along with the adapter (purchased from McMaster).
And it fits
Now I have to flip the bearing housing over and machine the bearing pocket. So this requires a clearance pocket in the fixture plate. This pocket also locates the part exactly on the center so I don't have to re-zero.
Or at least it should work that way. I'm having a bit of a problem with my machine: When cutting a circle, my Y axis dimension is always 0.002 smaller than the X axis dimension and this problem is getting worse, it used to be 0.001'' difference. When cutting a rectangle, the X and Y dimensions are always correct to +/- 0.0001''. I can't find any backlash in the system, and the math that calculates the circle seems to be correct in the program. I suspect a servo tuning problem, but not sure. I need to take a deep dive into this to figure out. For the moment, I can bore the critical dimensions to the correct size in a second operation, I left them undersize to accommodate the known error.
And it fits
