- Oct 10, 2018
- Location
- Oakville, Canada
I want to get a keyway broached into a cast iron pulley. It was formerly mounted on a different motor that has a flat spot on the shaft and was secured with just a couple of set screws. I've moved up from a quarter HP to one-half and the new motor has a standard 3/16" keyway.
I looked into buying a broach set but the least expensive option seems to be over $300 Canadian.
Is there a member in the GTA West that could help with a job like this?
Alternatively, is it possible to get "half-height" key stock? That way, I could make a 'flat' on the motor shaft and tighten the pulley set screw on that.
Craig
PS This is for my Atlas 618 resurrection. I am oh-so-close now!
Craig
