    Dismiss Notice
[Newbie] Quick-change Tool Post For Emco Compact 8
Discussion in 'MACHINE ACCESSORIES (Tables, Vises, Indexers)' started by slow-poke, Dec 10, 2016.
  1. slow-poke
    slow-poke Canada Active Member Active Member
    10
    8
    City:
    Toronto
    State:
    Ontario
    -Return to Top-
    I recently purchased an old Emco Compact 8 lathe and would like to purchase a quick-change tool post. This is the tool post on the machine at present:
    It clamps well, however it requires both the center bolt as well as the clamping bolt to be adjusted, I would prefer something like the one shown below:
    I'm looking for recommendations for a suitable one the same or similar to the one above as well as where to purchase.
  2. carlquib
    carlquib United States Active Member Active Member
    63
    28
    City:
    Hazelton
    State:
    Idaho
    -Return to Top-
    First question is where are you located? Tapatalk doesn't give any location information.
    Hello, my name is Brian and I'm a toolaholic
  3. Bob Korves
    Bob Korves H-M Supporter - Premium Content H-M Supporter-Premium
    3,578
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    You will need the dimension from the top of the compound rest to the center line from spindle to tailstock. Measuring to the tailstock center point is an easy way. Do not go by the swing of the lathe, which is mostly irrelevant. Most of the usual suspects sell those tool posts. The originals(?) are Aloris and Dorian and they are very nice and priced to match. There are lots of Chinese clones out there that work fine, but are not quite as nice, and are MUCH cheaper. I only really know the sources in the US, not Canada. For a search you could use "AXA tool post", which may be the one to fit your lathe.
  4. slow-poke
    10
    8
    City:
    Toronto
    State:
    Ontario
    -Return to Top-
  5. royesses
    royesses United States H-M Supporter - Premium Content H-M Supporter-Premium
    379
    63
    City:
    Norman
    State:
    Oklahoma
    -Return to Top-
  6. chips&more
    chips&more United States Active User Active Member
    1,219
    113
    City:
    Danville
    State:
    California
    -Return to Top-
    IMO I think the AXA size is too big for your lathe. I would look for a OXA size. And I don’t think Aloris makes a OXA size? But, many other companies do…Dave
  7. slow-poke
    10
    8
    City:
    Toronto
    State:
    Ontario
    -Return to Top-
    I think the OXA will be a better fit, even the OXA seems to use a M10 bolt, and the stud on the Emco is M8 and about 1.5" long
  8. mikey
    mikey Active User H-M Supporter-Premium
    2,244
    113
    City:
    Honolulu
    State:
    Hawaii
    -Return to Top-
    I agree. You need an OXA post. Aloris does make one in this size called the MA but it is quite expensive so I would opt for the A2Z version. The one on the orange lathe above is the Chinese one LMS sells. The A2Z one is made in the US and is nicer. I'm not sure but I think the Chinese tool holders will fit the A2Z post.
    You will need to make a new stud to mount the post. I made it over a year ago and cannot remember exactly how I did it but it isn't difficult. I'll ask my friend to look at his.
  9. royesses
    379
    63
    City:
    Norman
    State:
    Oklahoma
    -Return to Top-
    Here is the instructions sheet from LMS for the Emco 8mm conversion:
    Prazi or Emco lathe
    3112 - Quick Change Tool Post Set, 0XA, Tormach
    This tool post will mount on Prazi SD300 and SD400 lathes, many Emco lathes, and other lathes that secure the tool post with an M8 bolt. On the SD300 you can only use tools with up to 5/16" shank. It the Proxxon PD400 with a 1/4" (6 mm) spacer under the tool post.
    On these lathes, the tool post mounts to an M8 threaded hole in the cross slide. To mount the 3112 0XA QCTP you must modify the stud that comes with the 0XA QCTP to suit.
    Here is a simple adaptation:
    Use this stud to mount the 0XA QCTP to the compound or cross slide. If there are two tool post mounting holes, choose one of them to mount the 0XA QCTP.
    mikey likes this.
  10. slow-poke
    10
    8
    City:
    Toronto
    State:
    Ontario
    -Return to Top-
    royesses,
    Interesting, looking at the exploded view of the Emco #8 (assuming it's accurate), it appears they use a somewhat unique looking bolt, that does not appear to be threaded at the base. Since the threaded end is M8 the clearance hole in the existing tool post holder must be larger than M8, so I don't think the stud shown above will work. Perhaps I will have to remove it and tap the hole for a M10 stud?
    If I have to this it will obviously preclude using the original tool holder, I'm okay with that unless there would ever be a need to use the old style holder over the more convenient QCTP?
  11. slow-poke
    10
    8
    City:
    Toronto
    State:
    Ontario
    -Return to Top-
    Mike, Can you tell me what the part # is on the made in China tool post on the restored Emco, the image resolution is not quite good enough to make out the part #..... Thank you
  12. mikey
    2,244
    113
    City:
    Honolulu
    State:
    Hawaii
    -Return to Top-
  13. royesses
    379
    63
    City:
    Norman
    State:
    Oklahoma
    -Return to Top-
    I have not seen that type of set up that you show on the Emco. But it does look like you would need to tap it for 10mm. The 0XA is so good that I have not used my old tool holder since I got the qctp. I can't think of any reason you'd need to use the old one. You could make a bushing to fit the 10mm thread with a bore for the 8mm so you could use it if needed. Not a lot of work either way.
    If you get the Tormach 0xa you should get the 10 piece bag of dog point screws. The only problem I've had is with the screws that came with it, some of them were too tight.
    http://littlemachineshop.com/products/product_view.php?ProductID=4153&category=
    Roy
  14. mikey
    2,244
    113
    City:
    Honolulu
    State:
    Hawaii
    -Return to Top-
    The original Emco tool post stud is pressed in and is held in place by a roll pin. The hole for the pin is half in the post and half in the material of the compound itself. This allows it to resist turning forces and it works well. The problem is that the OD of the original post is too small and too short to fit an OXA post. I called my friend and he looked at it and that was enough to remind me how we did this job.
    I made a new stud that replicated the Emco stud, including the notch for the anti-rotation pin. The stud is long enough to work with the OXA tool post. The diameter of the stud is the same as the Emco post so that it fit through the hole in the compound. This means the OD of the stud is too small, so I made a spacer out of Delrin to take up the space. I then machined a washer 1/8" thick to go on top of the tool post and a nut with a handle to fit the thread I cut on the end of the stud. The handle locks the nut and post down solidly. With everything in place, the QCTP is rock solid.
  15. slow-poke
    10
    8
    City:
    Toronto
    State:
    Ontario
    -Return to Top-
    Okay, that makes sense. I will order the OXA QCTP and make a new stud.
  16. mikey
    2,244
    113
    City:
    Honolulu
    State:
    Hawaii
    -Return to Top-
    My friend sent a pic by phone so I can't send it here but it is essentially as above. I used Delrin for the spacer because it can be machined to very tight tolerances - there is zero play between the stud, the spacer and the QCTP but it turns easily when the lock not us loosened. It does not spin in use.
    That reminds me - this is a change gear lathe and there is a thread dial indicator was made for use with this lathe. They pop up on ebay from time to time so watch for it. I think the same indicator is used on the Maximat 7 but you'll have to check. Iwasamiller is the ebay seller with the most info - email him and he'll know.
    The other thing that you need that was never made for the Compact 8 is a carriage stop. If you want one, you have to make it. I made this one for my friend's lathe:
    If you need to bore a hole to a precise depth, you will need this stop. Not too hard to make if you have a milling machine. If you need details, PM me.
    royesses likes this.
  17. francist
    francist Canada Active User H-M Supporter-Premium
    617
    93
    City:
    Victoria
    State:
    British Columbia
    -Return to Top-
    So I'm confused -- the spec from LMS on the OXA says it needs 5/8" from top of compound to centreline of lathe.
    Slow-poke says he only has 0.536"
    How does this work, or is the LMS number a bit on the generous side?
    -frank
  18. slow-poke
    10
    8
    City:
    Toronto
    State:
    Ontario
    -Return to Top-
    Frank,
    Good point, looking at the previous images, when using a 1/2" tool with the original tool post, a shim (~0.1") is required to raise the tool to the center line.
    Now looking at the image of the 3112 on the restored unit, it appears that the tool can be level or even slightly below the base of the compound rest. I guess I will find out when it arrives.
  19. mikey
    2,244
    113
    City:
    Honolulu
    State:
    Hawaii
    -Return to Top-
    The 3112 rest will easily put a 3/8" bit on center.
  20. royesses
    379
    63
    City:
    Norman
    State:
    Oklahoma
    -Return to Top-
    It looks like the compound has a lot of meat on it. If you need to you could mill the .090 or more off the top to get the full capability of the qctp. If you don't have a mill maybe a local machine shop or a friend could do that for you. Just a thought.
    It is so great not to need to shim your tools. I mount different tools on the holders, set them on center and just leave them in the holder. When ever I order from LMS I add a couple of holders to the order so it does not take long to build up a supply of holders. The Tormach/LMS tool holders have .526 openings and will allow up 1/2" tools. If you don't need to use the old tool holder it would be simple to drill and tap the compound to 10mm and have a nice neat and strong install.
    Roy
  21. slow-poke
    10
    8
    City:
    Toronto
    State:
    Ontario
    -Return to Top-
    Roy,
    Or I might be able to mill 0.09 off the bottom of the QCTP (if necessary)
Share This Page
