- Dec 18, 2019
- 6,513
BS-0 came in from PM. Undamaged. The packaging was better, although the factory box seemed identical. This BS-0 seems for the most part, a lot nicer than the other one. It had a couple more accessories. The internal packaging was significantly better and fit the box and parts well. The manual was a little printed booklet, rather than over-xeroxed pages. Made a much more favorable impression. It felt like a first run set of parts, rather than the reject grade unit I first received. Oh, it turns 10 x smoother, and has hardly any backlash out of the box. That makes me happy. Still a couple of things that need some cleaning up, but much higher quality than the original eBay reject. If I touch the degree marks, they are rough, but at least they don't cut me, like the last one did. Although it probably would benefit from a teardown, it works well enough that I have no good reason to do so. For now, it will stay intact. Have a couple of questions.
Are there any surfaces that one can indicate on? How do I know it's even level? I'm not trusting the marker on the side. Right now, 0 degrees doesn't line up with the line. This unit has a 5" 3 jaw chuck and a MT2 dead center. I'm guessing that the 3J doesn't have the lowest TIR. For indicating would one use a spindle mounted "Indicol" holder? Are the $15 eBay ones ok, or do I need to pony up for the real Indicol holder? How does the Indicol attach to a DTI?
The C-clip that is used to hold on the indexers, looks like it was designed to lacerate unsuspecting fingers. On mine, the tips point up, also the tab at the back isn't bent correctly and has really sharp edges. Can one bend these clips much, or is it better to try to find a new one? For instance, the back tab is bent maybe 10 degrees and should be closer to 90 degrees. Also the clip is putting a lot of tension on the indexers, so they are very hard to move. (When the indexers are locked to each other) Would stoning the top and bottom surfaces of the indexers to help this? The indexers seem to be cast and have a somewhat rough surface.
On my dividing head, the chuck was attached to the backing plate with SHCS. Of course there's no way to remove the chuck from the plate without spinning off the backing plate. There's no access to the socket heads. On the eBay BS-0 they used hex head bolts. When I first saw the new BS-0, I thought, why would one make a design like that? It was simple to open up the jaws off the chuck a little and tapped with with a brass hammer and spun it off. I've left the chuck attached to the plate for now.
Should the TIR of the chuck assembly be poor, what are the options? Not really sure how one would shim a 3J. I see one can get a MT2/ER32 collet. I have an ER32 set for my lathe, so I could commandeer them. I tried fitting a MT2 dead center and it seemed to fit well. Apparently that is almost the same as B&S-#7? The dead center that I received from the BS-0 has some burrs on the machined taper, how do you fix them? Fine diamond hone? How do you do it without damaging it?
There's a plate with a hole and two slots in it. Is this to engage a lathe dog? I don't understand why they supplied so many bolts for it, there were 5 with my kit. One to attach to the dead center, one to capture the dog leg, what are the other ones for?
Apparently there are some keys supplied for the head and tailstock, but they don't fit my table. They are 16mm wide and the table has 12mm slots. And the counterbore is 10.6mm. Seems like the keys would be a pain, as the units would never sit flat off the table. For a hobbyist, do the keys help?
Eventually want to make some gears for my mini-lathe. But before I do that, are there some sort of beginner's exercises that make sense? I'm really starting from the beginning here, so if you know of a few things to try first to build gear cutting skills, please let me know.
