- Nov 14, 2014
- 851
Iam getting ready to install and wire up a TECO VFD to my 3 Phase Baldor pedestal grinder. I have not wired up or worked with a VFD previous to this.
The VFD is a 110v input -220 3 Phase output unit. My 110 v shop circuit has the standard URL approved 20 amp, line (black), neutral (white), ground (green) three wire circuit configuration coming out of my sub panel.
So my question is: is it correct that I should connect my 110 v input neutral (white) wire to the L3(N) terminal shown in the attached photo of the VFD?
AND, it should not be connected to the L2 terminal??
Note: the otherwise easy to understand tech manual that comes with the VFD has a diagram that says exactly the same thing as the picture - no instructions on how to wire 3 strand wire to the input side of the VFD.
Basically I've always been confused about which terminals (L1,L2,L3) are normally associated with 110v and 220v 20 amp circuits. - (well, I get the black wire should always be L1 - but have never understood what to do with L2 when wiring two wire circuits with two strand black and white (red) power cords)
Thanks for any clarification anyone can offer.
Glenn
Glenn
