- Jul 14, 2017
- 2,451
Today i continue working on this car, i change the alternator regulator and installed it to the engine. Then i installed the rest of prats i took of only left the cooling system disconnected, fired it up back it in my driveway and flush the cooling system using my pressure washer. I also remove the driver's side fender, headlight and fender liner. Then i spent 2 hours with the pressure washer and degreaser to get the front end clean od any dirt or grime. I also change the passenger tire to mach the other side. Drove it up and down my street seams to drive fine only the cooling fans never com on and i bleed the air of the cooling system and the alternator is still not working.
