- Feb 5, 2013
Since im restoring my lathe i thought i might aswell make a thread on it. Hope someone find it either entertaining or informative.
I aquired this lathe last month cheap after many years dreaming of owning one.
It is a german quality lathe from the 60's or early 70's and was in use at a local hospital until they upgraded to newer machines. Since then it had one owner that passed away then stored somewhere up to the point where i got it. Sadly under transportation from or to the storage, the topheavy lathe tipped over and was somewhat damaged. Nothing major but enough that it needs some work.
The damages where two cracked cast iron covers, bendt cross-feed dial"axle" and some minor issues like chipped paint etc.
While it was in use at the hospital they also repainted the tray and some other surfaces in red that are now chipping off, aswell as doing a rather poor job.
So my plans so far:
Remove old paint, prep and new stock paintcode.
Braze the two craked cast iron covers.
Get some "expert help" going over bearings and replace if needed.
Change the V-belts and engine mounts.
Straighten or get a new used cross-feed shaft.
Find missing front cover.
This is my progress this far:
More to come soon.
So my plans so far:
More to come soon.
