- Feb 16, 2015
- 20
Gunrunner you need to order a set of these for the Z axis hand crank. Bill did you just spit coffee on your monitor? :rofl:
Just clean it up, Paint it and forget about those drill holes.It's a brown and sharp. It's very tight and the bottom is flat still. I'd love to see this baby redone. How would I go about it? What would you guys do?
Wilton does not make milling vises, they only make drill press vises. A milling vise has much more mass, rigidity, and in some cases a precision instrument of it's own.If you have the time and energy, go for it. Otherwise I would suggest just buying a new/used good Wilton.
OP - I'd fill the craters with Devcon and surface grind or scrape the top flat. Just to keep chips out and your parallels from falling in. Clean up the bottom and the top of the jaws and it should be alright, that looks like a fine vise as long as the jaw doesn't have too much slop.
Oh yes... Wilton does make milling vises, got a lot of them on their web site, but they are really expensive. A small one runs around $280.
You still got a usable vise. I would fill it with "All metal" and file it smooth and flat. It wouldn't be as hard as the cast iron , but if you don't abuse it , it will last years.
