[4]
Retrofit a 70mm Tilting Vice
[10] Like what you see?
petcnc
Active Member
Dec 29, 2012
198
Likes
230
#1
When I bought my mini mill I also bought two small vices (70mm) to hold my work on it.
One of them was a cast iron tilting machine vice.
Jaw opening, dimensions and the looks of it (I thought) was appropriate for the work envelop of my mini mill. It was not cheap though! But as I thought it would be useful I happily paid the money for it.
As I was new in milling I did not use the vice for months. A few times I tried to hold something and mill it in an angle I found it to be real difficult.
I blamed my lack of experience and let the vice on a self gathering dust.
A few years later, having learn a few things more, I tried to mill a piece of aluminum in an angle of 45. I noticed that the vice had real problems in holding the piece. Jaws were not parallel!
A classical Chinese quality control problem I thought. Seeking the cause of the problem I discovered that the moving jaw supporting rod was placed in a funny way! The supporting hole at the fix jaw side was off by 1 mm.
I was scratching my head for a solution to the problem as on the one hand, I did not wish to throw it away and, on the other, there is always a challenge to make something work as it should!!
The only solution I thought, without major interventions to the vice body was to enlarge the holes by 2 mm as to center the problematic one and make a new supporting rod for it.
The easiest part was making the rod. I had raw material.
It was a matter of minutes to make it on the minilathe.
It was a challenge to properly secure the vice on the mill table, using an angle plate and a 1-2-3 block I worked it out
Reboring the correctly set hole was easy, but to find the exact offset to rebore the “wrongly placed” hole was a challenge. It took time and many trials to work it out!
Fitting the new rod to the vice was easy. Here is the back side.
And the front side
The new 12mm rod made it stronger in comparison to the old 10mm one
The vice works as it should now!
The only little thing I have to fix now is that the movable jaw, although perfectly parallel to the fix jaw, has been moved 1mm to the right.
Thanks for reading
Petros
Karl_T
Active Member
Oct 14, 2014
825
Likes
292
#2
great refit job. Yep,when you buy these inexpensive asian tools, you bought a project.
petcnc
Active Member
Dec 29, 2012
198
Likes
230
#3
100$ for a little vice + postage you can hardly call it inexpensive!
I must be very unlucky with all my vices though as all of them needed a lot of work to make them behave like tools!!!
Initially they were just expensive paper weights!
hman
Feb 17, 2013
1,542
Likes
1,062
#6
Nicely done! It's an unfortunate fact that all to often, what you get from China is not a tool ... it's a "kit" ;~)
[6]
[5] [7]
