Started a small project this week to help with some other work.
I needed a hex hole in the end of a rod - therefore I needed a rotary broach.
This was the sketch I came up with for a simple broach.
The tool bit will be made from 1/2" W1 Steel and the other body parts from Stressproof Steel.
The bearing is a 1/2" ball from McMaster Carr.
To make the cutters, I made up some angle plates that allow the spin indexer to sit at 2 degrees to the table.
I started by cutting the six flats to the correct depth and then added the recess at the root of the cutter to make the sharpening easier on a diamond plate.
With the recess there was no risk of the shoulder riding up on the plate and changing the angle at the cutter tip.
This is the assembled broach with a hex cutter installed.
The cutter has an indexing flat and a 1/4"-28 clamp screw
The cutter holder rides on a 1/2 inch ball held in two sockets. The sockets in the body and holder were cut with a 1/2" ball end mill.
Body and bearing.
Cutter holder and the bearing. The body, holder and ball are assembled with some EP grease between them.
The groove in the cutter holder is for the four 5-40 screws that hold it in the body when not in use.
If the sockets for the ball are not exactly as shown, the groove has to be modified to ensure that the screws do not touch the sides when in motion.
Both the cutter and the cutter holder were hardened via torch and then tempered for 4 hours in a 450 degree F. sand bath. The tempering left both still quite hard but could certainly be marked with a file.
Once they were cleaned up, the bore of the cutter holder had to be honed to fit the 1/2' shank of the cutter. Used a shop built blind hone of aluminium and 3000 mesh diamond compound.
The end and flats of the cutter were then sharpened on a 320 grit diamond plate.
The cutter worked fine on aluminium and would not have a problem with brass. I will have to try on mild steel to see how it goes.
This cutter was 0.375 across the flats and 0.433 across the points. The rod was drilled with a 5/16, 0.350" deep and then counter drilled with 7/16 0.05" deep to allow the bit to centre on the hole.
Sorry for the quality of photos of the rod end, but it did seem to cut a very acceptable hex shaped hole.
Body and bearing.
