- Nov 9, 2010
- 306
I needed to make some wheels narrower (for racing only, not going on the street) so I dreamed up a idea after viewing all you guys projects. I used scrap from the pile and the only cost was for the bolts. It is the largest project that I have tried so far and am very pleased with the out come. I see where i made some mistakes and will hopefully not do that in the future :lmao:. I documented the project as I went so I have some picts, hope your not bored with them.![Pipe-1.jpg Pipe-1.jpg](https://www.hobby-machinist.com/data/attachments/33/33663-0db909e4657b39dd2915e662f873d06f.jpg)
![Pipe-2.jpg Pipe-2.jpg](https://www.hobby-machinist.com/data/attachments/33/33667-cb29a618e2298466677fba2e9526802e.jpg)
![Pipe-4.jpg Pipe-4.jpg](https://www.hobby-machinist.com/data/attachments/33/33665-2a204fd12853827c90841705c4c7bbbe.jpg)
![Pipe-3.jpg Pipe-3.jpg](https://www.hobby-machinist.com/data/attachments/33/33666-ec6168b7dfe83f7471bdd76ad75a252c.jpg)
- - - Updated - - -
I used a axle hub flange for the size template then decided to make it fit Ford, Chevy and Dodge wheel patterns so I could do virtually any five bolt wheel if I desired.
![Plate-1.jpg Plate-1.jpg](https://www.hobby-machinist.com/data/attachments/33/33674-feae3b9f5b91200f07add92156150101.jpg)
![Plate-2.jpg Plate-2.jpg](https://www.hobby-machinist.com/data/attachments/33/33673-00ec44e6ca0fdedaa3be830c484863b9.jpg)
![Plate-3.jpg Plate-3.jpg](https://www.hobby-machinist.com/data/attachments/33/33672-a6a27743887e2ed0bf9b5ca0389042af.jpg)
![Plate-4.jpg Plate-4.jpg](https://www.hobby-machinist.com/data/attachments/33/33671-5f8152b77df6d88cff36069bce94a558.jpg)
![Plate-5.jpg Plate-5.jpg](https://www.hobby-machinist.com/data/attachments/33/33670-c9bcadf28ac2ff00473502d974bb9ef7.jpg)
![Plate-6.jpg Plate-6.jpg](https://www.hobby-machinist.com/data/attachments/33/33669-6a0ec4ff8cb09902bbfb552c1084ce53.jpg)
![Plate-7.jpg Plate-7.jpg](https://www.hobby-machinist.com/data/attachments/33/33668-773b4c57f17821ff0976a20d3004e133.jpg)
- - - Updated - - -
Cut a lip in the top and bottom caps as well as one in the pipe so they fit snug, then welded the bottom cap on from the inside and bolted the top cap on so I can remove it and make other sizes in the future if I find the need.
![Top Cap-1.jpg Top Cap-1.jpg](https://www.hobby-machinist.com/data/attachments/33/33679-8da6f9e7cafe94f167e77f8a0f9e7c5c.jpg)
![Top Cap-2.jpg Top Cap-2.jpg](https://www.hobby-machinist.com/data/attachments/33/33678-183fa977c66dac2ceb17177972bed8fc.jpg)
![Top Cap-3.jpg Top Cap-3.jpg](https://www.hobby-machinist.com/data/attachments/33/33677-463bc2c14a6b49bbe173abc3f1b425f7.jpg)
![Top Cap-4.jpg Top Cap-4.jpg](https://www.hobby-machinist.com/data/attachments/33/33676-53bee734f0f713cb4196ecdb35711f03.jpg)
![Top Cap-5.jpg Top Cap-5.jpg](https://www.hobby-machinist.com/data/attachments/33/33675-c9571d3a3c45f0b7f2af7a158a9926e4.jpg)
- - - Updated - - -
Needed to be able to distribute the force as far out as possible on the table so I grabbed some old angle iron and cut some pieces to mount to the T-Slots on the table.![Angle-1.jpg Angle-1.jpg](https://www.hobby-machinist.com/data/attachments/33/33683-6154c803ca07a28eaf9884adf8eb5373.jpg)
![Angle-2.jpg Angle-2.jpg](https://www.hobby-machinist.com/data/attachments/33/33682-3d68359b7aa609a5d814051daa451b57.jpg)
![Angle-3.jpg Angle-3.jpg](https://www.hobby-machinist.com/data/attachments/33/33680-5d337e266bc109e1c3d6afa1b689861d.jpg)
![Angle-4.jpg Angle-4.jpg](https://www.hobby-machinist.com/data/attachments/33/33681-e3b4c941aad659a7d5ddec3a60453504.jpg)
- - - Updated - - -
- - - Updated - - -
- - - Updated - - -
