Rotary Table Quick Centering Mandrel
darkzero
Global Moderator
Staff member
H-M Lifetime Diamond Member
Nov 27, 2012
7,863
Another quickie planned years ago that I finally got around to. Centering tool for quick setups. Will be good for 90% of the stuff I do. If I need higher accuracy I'll indicate.
291282
Here's what I started out with. A threaded drill chuck arbor purchased years ago, (luckily I didn't loose it), a piece of 4140, & a piece of 6061.
291283
Tapped the 4140 to thread onto to the arbor, machine, & sand/polish to final size.
291284291285291286
Making the "emergency" sleeve & washer.
291287291288291289
Here's how I use it. Mount the mandrel in a collet. Rotary table bolts are loose. Drop the the quill to seat the mandrel in the RT MT taper, then snug the RT bolts.
291290
TIR of the mandrel in the mill spindle is .0004"-.0005".
291291
TIR of the RT after simply using the mandrel to center is .0007"-.0008", this was on the very first try. If I'm more careful about it I can get it lower but the point of this tool is for quick & dirty centering which will be fine for me in most cases.
291292
The reason for the long mandrel is after centering & snugging down the RT, with the mandrel seated in the RT, I can quickly center my chuck. Tighten the jaws on the mandrel, then snug down the chuck. Again, if I need higher accuracy I'll indicate the chuck in also.
291293
To eject the mandrel I use the washer & bolt.
291294
And in any case the mandrel might get seated to where I can't simply pull it out by hand, I use the sleeve, washer, & bolt.
291295291296
And finally storage.
291297291298
Thanks for looking! :big grin:
I've been wondering how I was going to manage that. Thanks for the how to...
Thanks Will, another project on my list.
Another good accessory for the RT is a tappped slug for the center so you can use as a hold down hole. I made two one with a flange that sits in a recess on bottom of RT hole then put a threaded rod to bring to top surface after alignment process, and a expanding one in case I forgot to put the other one in BEFORE I mounted the RT to the mill. Nice job!
Nice job, Will! As usual, very high quality pics that make it simple to understand.
I mean, its not like I don't already have a huge project list already ...
Haha, thanks Mike!
