SB 10k Belt Replacement
dcms
Aug 21, 2011
22
What is the best way to replace the belt between the cone drive and the spindle? I can't imagine you need to dismantle the spindle and other drive works to install a belt??
I see on the forum some discussions about gluing a belt and using a link belt. I suppose that is to allow the belt to be replaced without dismantling the lathe.
Any advice on "where" to get a new belt is appreciated.
There are a couple of ways to replace a belt, one way is to get a leather belt and splice it then clamp, glue and wait 12 to 24 hours or get a car belt (serp.) then splice as described or use a link belt like I did and only takes 2 minutes and no need to splice, just remove extra links and re-attach (see pic). I had mine on the lathe since march and it does not slip, but the motor v belt does. I will not go back to leather as I love the link belt. The under drive units should work also as long as there is room for the extra thickness. Mine came as 60", but I only needed 54".
Paul
Thanks for the help. This seems fairly straight forward. I don't have a way to post a picture yet. Will post one as soon as I get a way to transfer photo to computer.
