- Feb 1, 2015
- 9,649
My strategy for removing unwanted bends, creases, etc. is to try to do the opposite of what put the bend, crease, etc there in the first place. This is more successful with simple bends as there is relatively little stretching of the metal.
In your case, my approach would be to support the main bidy of the cover on a resilient material and either pull the hinge down to restore it to its correct position or to hammer it back with a soft faced hammer. or both. With a little patience, you should be able to restore the cover to a nearly like new state.
In my experience. localized heating should be avoided if possible as it can lead to warping in nearby areas.
