- Jul 29, 2015
- 91
Simple to machine from 3/4" dia. steel. Copy base dimension from a standard shell holder, and bore top to rim size clearance for whatever cartridges you reload. Much easier to just drop a case in and de-prime if you have lots of cases to do, faster than sliding the case in on the open side of normal shell holder. One on left is bored for two different size rims, one on right 3 rims. Use a standard de-prime die, and your good to go.
